Frequent Contributor II
Issue with RFC3576 disconnect
I have defined the rfc3576 server in the controller.  I have made double sure that the keys match the radius keys on clearpass guest and on the controller.  When I send a disconnect from the cp guest I get this message from cp guest
"Disconnect failed – Administratively Prohibited"
On the controller I get the following:
Jun 21 13:13:57  authmgr[1540]: <520001> <DBUG> |authmgr|  [rc_rfc3576.c:238] IP:0.0.0.0, Name:63954915 sessid=63954915001BB1A74547-02, reqcode=40, rspcode=42, nack=1, error_cause=administratively prohibited
It bothers me that the IP is 0.0.0.0.  Is this normal?  I was expecting this to be the radius server (cp guest) and used to match the corresponding key defined in my config.  If this is indeed the case then this explains the error message.  Not sure where to define that on cp guest (amigopod)
Re: Issue with RFC3576 disconnect
Did you associate the RFC3576 server with the AAA profile of the WLAN that needs to do disconnects on the Aruba controller?  It is not enough to define it.  You need to Assign the RFC3576 server to the CPguest AAA profile on the controller.
cj I yield once more to you superior knowledge :smileywink:
You were completely correct, and now it works perfectly.
Cheers!
Cheers!
Soapdish,
I am just more lucky than you in some situations ;)
Would that be the RADIUS Accounting Server group where you would associate the RFC3576 server with the AAA profile?
Moderator
It is below the reset of the settings for our aaa profile - see screenshot below
Contributor II
Awesome.. Helped me a lot!!
Bharani..
