Issues regarding CPP Guest Access and IAP securelogin.arubanetworks.com revoked cert
Hi everyone!
I’m facing an issue regarding to the recent securelogin revoked certificate.
I had followed the Arubas’s recommendation and I have now a public wildcard certificate. I installed the certificate on the Virtual Controller for captive portal. On Clearpass, web login configuration, I replaced securelogin.arubanetworks.com with something.company.com –“*  Address: ” field. My cert is *.company.com.
Guest users associate to the SSID and then they are redirected to clearpass login form. They validate their credentials and then redirected to https://something.company.com/cgi-bin/login. Any kind of browser says:
something.company.com’s server DNS address could not be found.
DNS_PROBE_FINISHED_NXDOMAIN
And then no access to the network.
Before Aruba’s certificate revoked, doing a nslookup to securelogin.arubanetworks.com returns an address 172.31.98.1, that points do the virtual controller.
I’m confused… how to get guest users connected with clearpass and a public wildcard certificate? There is any cookbook? I spent several hours googling and nothing comes up.
Thanks and best regards,
JM
Re: Issues regarding CPP Guest Access and IAP securelogin.arubanetworks.com revoked cert
Joao Martins wrote:
Hi everyone!
JM
tl;dr
Wildcard Certificates are supported starting in Instant 6.5.0.0-4.3.0.0 Early Deployment code.
Hi!
Thanks everubody, indeed version 6.5.0 solved the issue.
Everything working well as expected.
Thanks!
JM
Hi.
I am having the exact same issue that you had. The virtual controller does not intercept DNS traffic to server.somecompany.com (that I have changed the value to in Clearpass).
I am also running 6.5.0.0-4.3.0.0.
After you installed the *-cert in the virtual controller did you do anything else? Restart all APs for instance?
Best regards,
Petter Miller
Hi Petter.
Please check something like this on Clearpass Guest Management:
You must always use captiveportal-login.your.domain. I recomend you install the cert also on ClearPass (no big deal, it´s a *.cert), not mandatory for this case.
If you accomplish this, I believe you have solved the issue.
Let us know if you have been successful.
Best regards,
Joao Martins
Hi Joao.
captiveportal-login.your.domain resolved the issue. It now resolves captiveportal-login.your.domain to the internal VC address 172.31.98.1 which is correct.
I had already installed the *-cert on both the virtual controller and on Clearpass. Everything seems to be working fine now.
Thanks for helping out.
Best regards,
Petter
