Juniper Trapeeze Controller authentication with CPPM
Having issuse using Captive Portal with MAC caching for Juniper Trapeeze AP's.  The authentication does work if we after initial try we turn off the client WiFi and then trun it back on.  The second attempt works because of the MAC caching.
Any assistance would be much appreciated...
Re: Juniper Trapeeze Controller authentication with CPPM
How are you doing the intial auth and what attribute are you sending back ?
Can you take a screenshot of the webauth ?
Thank you
Victor Fabian
Lead Mobility Architect @WEI
we are actually on with support now. He has remote control of the PC.
We setup the pre-auth check to Radius to allow for the MAC to be cached.
Controller Initiated - require user name and credentials (we did try all options here)
Hopefully he resolves it and I can update all
Lou Occhicone, Jr.
WLAN Sales \ Design Engineer \ Systems Engineer
Aruba ACMP, ACCP \ Avaya ACSS \ Nortel ACDS
908-914-7704
support provided the attached document which got it resolved
