Load Balancing across Clearpass Servers
  • 1.  Load Balancing across Clearpass Servers
    Posted Aug 08, 2014 09:35 AM
    Hi:
    I have two Clearpass servers, but all requests from my Aruba controllers are going to the publisher Clearpass server.
    How do I piont different controlles to different CPPM servers, so that the subscriber Clearpass does some of the work?
    Tony
  • 2.  RE: Load Balancing across Clearpass Servers
    Posted Aug 08, 2014 09:38 AM
    You have three options:
    1) If you're using AOS 6.4, check the RADIUS load balancing box in the server-group config.
    2) If you're not using AOS 6.4, create two server groups, one with server A in slot 1 and Server B in slot 2, and then in the second server group flip them. Then assign these to different AP groups.
    3) Use a hardware load balancer.
  • 3.  RE: Load Balancing across Clearpass Servers
    Posted Aug 08, 2014 10:02 AM
    Hi Tim:
    Thanks for the reply.
    I'm still using a few 3400 controllers, so I'm on 6.3.
    To use the second option you mentioned, am I correct in understanding that I would
    Create a new server group with the order of CPPM servers swapped
    Create a new aaa profile that uses the new server group as the dot1x-server-group
    Assign the new aaa profile to a wlan virtual-ap?
    Tony
  • 4.  RE: Load Balancing across Clearpass Servers
    Posted Aug 08, 2014 10:08 AM
    Right. I actually left out a step or two.
    You would need to duplicate both your AAA profile and your virtual-ap profile and then set the second variation of the server-group in the duplicate. So it would look something like this:
    SSID1_vap-profile-a
    Aaa-profile dot1x-A
    Server-group clearpass-A
    SSID1_vap-profile-b
    Aaa-profile dot1x-B
    Server-group clearpass-B
    It's a pain to set up at first, but it works.
