last person joined: 11 hours ago
Machine authentication failing with error code 9002
This thread has been viewed 43 times
  • 1.  Machine authentication failing with error code 9002
    Posted Aug 12, 2016 12:19 AM
    Hi All,
    I tried to do machine + user authentication with EAP-TLS as authentication method.
    But when doing machine authentication, its getting timeout and showing below error in CPPM,
    Error Code: 9002
    Error Category: RADIUS protocol
    Error Message: Request timed out
    Alerts for this Request
    RADIUS Request Timed out
    And after failing to do machine authentication the same machine is  doing user authentication. Which is working as expected.
  • 2.  RE: Machine authentication failing with error code 9002
    Posted Aug 12, 2016 12:24 AM
    Wired or wireless?
    What vendor?
    Who is issuing the certificates?
    What version of Windows?
    Is the supplicant configured through group policy?
  • 3.  RE: Machine authentication failing with error code 9002
    Posted Aug 12, 2016 12:27 AM
    Its wired.
    Client is windows machine & the switch is Cisco.
    CA is issuing certificate.
    Windows 7.
    I guess supplicant is configured through group policy.
  • 4.  RE: Machine authentication failing with error code 9002
    Posted Aug 12, 2016 06:59 AM
    9002 and a timeout can be because a client is asked to trust a server certificate, but does not.  Has this ever worked?  There is quite a bit of work to get EAP-TLS working.
  • 5.  RE: Machine authentication failing with error code 9002
    Posted Aug 12, 2016 07:14 AM
    Thanks Colin,
    Turned out to be a wrong machine certificate installed on Client machine.
    Changed the certificate and worked :)
  • 6.  RE: Machine authentication failing with error code 9002
    Posted Apr 09, 2018 04:55 PM
    I have this same error on my Macbook Pro. I have used this Mac previously on this network but ever since I onboarded and tried to un-board it. I have not been able to join the wifi anymore.
    Packet capture shows that Macbook is sending Response, Legacy Nak (Response Only).
  • 7.  RE: Machine authentication failing with error code 9002
    Posted Apr 09, 2018 04:56 PM
    Please start a new thread. This one is almost 2 years old.
