NMAP does not work
I cannot make nmap work at a certain environment. I enabled nmap in cluser settings, enbaled profiling in the services and ran a subnet scan. Still no port data in any profiled endpoint.
If I am not missing something in the config, it may be a firewall blocking issue. I will investigate in the FW logs, but I'd also like to know if there are ways to troubleshoot nmap in CPPM.
The simplest way would have been to run nmap from the Linux CLI on CPPM server, but the OS shell it is not available to mortals which are not TAC.
