Regular Contributor I
Problem with special type in SMS
I have a problem with the SMS service in ClearPass. I would like to send a SMS with usernames that contain a "+" (usernames are phonenumbers). The issue is that the "+" is deleted from the SMS. It's not coming from my SMS provider (I have tested it, works well).
Any idea ?
Dimitri
MVP
Re: Problem with special type in SMS
Hmm - seems the reply by email doesn't work anymore - as my reply by email landed in a different post..
Anyways:
I have a self-registration that allows +<countrycode><phonenumber> and registers that as username. The sms receipt shows the + just fine. I’m using this code {$u.username|escape} in the sms receipt.
Regards
John Solberg
-ACMX #316 :: ACCX #902 :: ACSA
Aruba Partner Ambassador
Intelecom/NetNordic - Norway
Remember to Kudo if a post helped you! || Problem Solved? Click "Accept as Solution" in a post!
Thanks.
I don't understand because I have the same code and the + is still escaped.
Regards
Dimitri
MVP
Is this through the self-registration? What happens if you go to the SMS gateway in Administration and Send SMS directly from there.
Just type in various letters and see what arrives at your phone.
Regards
John Solberg
If I do it thru the SMS gateway, it's the same. The + is escaped.
But if I send a SMS thru the SMS provider (directly by its website), no problem, I can see all types.
Thanks for your help.
Dimitri
MVP
Try this..
Edit the SMS Gateway
Check the box for "Convert text to hex-encoded UTF-16"
It really shouldn't be a problem with + sign tho..
Regards
John Solberg
As I am using SMS Global, there isn't this option.
Edit : I have tried to configure a custom http handler, it seems that SMS Global doesn't support utf-16.
Dimitri
MVP
Are you saying the + is removed or escaped to some other character?
You are certain the + is saved in the username? (just checking :))
You could try to use the ClearPass Guest SMS Service gateway and see if the same happens. Won't help you much, but you might be able to narrow down where the issue might be.
Regards
John Solberg
The + is removed.
Yes the + is saved in the username.
Ok I will try with ClearPass Guest SMS Service gateway and give feedback.
Dimitri
So I can't try the ClearPass Guest SMS Service gateway, can you do it in your lab ?
Dimitri
