Re-direct to an external captive portal
  • 1.  Re-direct to an external captive portal
    Posted Nov 30, 2016 07:14 PM
    Is it possible to re-direct our guest clients to a 3rd party captive portal?  We are using an Aruba Mobility Controller, model # Aruba3600-US, version 6.3.1.15.
    We don't want Aruba to do any kind of authentication but re-direct to our web-filter which is active directory enabled.  It will provide the end user with the appropriate filtering and Internet access.
    We are trying to avoid a double authentication situation, 1 by Aruba and the 2nd by the filter.
  • 2.  RE: Re-direct to an external captive portal
    Posted Dec 02, 2016 09:50 AM
    You'd need the external captive portal to somehow tell the controller that access has been granted. Can you please share more details about this external captive portal?
