Redirect Cisco Wired Guests to Captive-portal
  • 1.  Redirect Cisco Wired Guests to Captive-portal
    Posted Jul 27, 2016 07:03 AM
    Hi
    I am working in a setup in which the users whom dont have a known MAC address will be assigned to the guest VLAN, and its working fine.
    But I want now to redirect their initial web access to the captive-portal page, and then after authentication get full internet access.
    What is the procedure for this target?
    Attached a snapshot for the service I created to authenticate the guest users (non-802.1x enabled users);
    if MAC known, then allow-access
    if MAC unknown, then assign it to Guest VLAN
  • 2.  RE: Redirect Cisco Wired Guests to Captive-portal
    Posted Jul 27, 2016 07:23 AM
    In this link you can find how the enforcement profile needs to be configured and the ACL on the switch
    http://community.arubanetworks.com/t5/AAA-NAC-Guest-Access-BYOD/Cisco-URL-Redirect/td-p/202713
    You also need to make sure the following is enabled on the switch:
    Ip device tracking
    Ip http server
    Ip http secure-server
    Get Outlook for iOS
  • 3.  RE: Redirect Cisco Wired Guests to Captive-portal
    Posted Jul 27, 2016 07:50 AM
    Hello Viktor
    Thank you.
    but I think the switch must be L3 and the gateway for guest VLAN must be terminated on the testing switch so the access-list can be applied, else it will not be applied, right?
    As i am using Cisco 2960 switch in my setup, and the GW for the guest VLAN is terminated in another switch, so what will be the case here?
  • 4.  RE: Redirect Cisco Wired Guests to Captive-portal
    Posted Apr 11, 2017 05:16 PM
    Did you ever get this working? I'm looking at doing the same also with 2960s.
    Thanks in advance.
  • 5.  RE: Redirect Cisco Wired Guests to Captive-portal
    Posted Apr 12, 2017 03:06 AM
    No, I didnt give it another try :)
    Let me know if you have postive results please
