Redirect Onguard with Wired
  • 1.  Redirect Onguard with Wired
    Posted Jun 11, 2018 05:49 PM
    How can redirect with Onguard ?.
    At the Wired level, when a user is categorized as "unhealthy", is there any way that from the same wired end-user (unhealthy) get a redirection link or pop-up in order to download patches necesaries.
    Regards
  • 2.  RE: Redirect Onguard with Wired
    Posted Jun 11, 2018 05:55 PM
    What is the network device?
  • 3.  RE: Redirect Onguard with Wired
    Posted Jun 11, 2018 06:00 PM
    Sorry, the deployment is with Cisco SW and Clearpass.
  • 4.  RE: Redirect Onguard with Wired
    Posted Jun 11, 2018 07:36 PM
    See if this helps
    https://community.arubanetworks.com/t5/Security/Cisco-URL-Redirect/td-p/202713
    Also make sure you have the following commands:
    Ip http
    ip http secure-server
    Sent from Mail for Windows 10
  • 5.  RE: Redirect Onguard with Wired
    Posted Jun 12, 2018 10:14 AM
    Thanks Fabian.
  • 6.  RE: Redirect Onguard with Wired
    Posted Jun 11, 2018 07:34 PM
    What type of switch are you using ?
