Roaming between controllers on Guest SSID with Captive Portal
  • 1.  Roaming between controllers on Guest SSID with Captive Portal
    Posted Jul 29, 2013 05:41 PM
    Hello All,
    Here is a quick outline of the issues. We had 3 floors in a building and using a pair of 3200 controllers in VRRP we were able to get full coverage of the office. We recently expanded to 3 more floors, and installed another set of 3200s in the same VLAN. It shares the same 3 VLANs, Guest, MGMT, and Employee. The employee network is working fine as when the user moves between floors the OS is able to reauthenticate via EAP-TLS and the user does not notice.
    Or issue is that since the captive portal is configured for the Guest network, a user on this network will have their connections dropped and be foreced to re-authenticate to the network.
    Is there any way to share network authentication state between controllers to allow for a device to roam between the two without having to re-authenticate? We are using Amigopod for our captive portal, but do not have RFC3576 features enabled.
    We also have airwave, but are only running in Monitor mode.
    #3200
  • 2.  RE: Roaming between controllers on Guest SSID with Captive Portal
    Posted Jul 29, 2013 05:49 PM
    You can enable Mac caching so that the devices can retain their auth status for certain amount of time :
    http://support.arubanetworks.com/DesktopModules/Bring2mind/DMX/Download.aspx?TabId=77&DMXModule=512&Command=Core_Download&EntryId=6205&PortalId=0
    This would work across different controllers
  • 3.  RE: Roaming between controllers on Guest SSID with Captive Portal
    Posted Jul 29, 2013 06:25 PM
    U may also consider doing L2 Tunnel between two working masters.
    (The user DB is internel on each master ..thats why your clients need to re-auth when passing from controller to controller)
    How to? More info
    https://arubanetworkskb.secure.force.com/pkb/articles/HowTo/R-717
    Some more relevent info: (AirHeads)
    http://community.arubanetworks.com/t5/Guest-Access/Guest-Network-Questions/td-p/31744
    http://community.arubanetworks.com/t5/ArubaOS-and-Controllers/Using-GRE-Tunnels-to-centralize-L3-access/td-p/2831
