Regular Contributor II
SCCM is not working with onguard as expected.
Hi All,
I am doing POC with CPPM, customer requirement is onguard to work with SCCM for patche management.
We tested several things but onguard is not checking for missing patches or patches available.
But If we push patch form SCCM server manually, we are getting the patch.
Re: SCCM is not working with onguard as expected.
How are you checking for missing patches?  Did you see the page here?  http://www.arubanetworks.com/techdocs/ClearPass/Aruba_CPPMOnlineHelp/index.htm#CPPM_UserGuide/Posture/WindowsPatchManagement.htm
What client operating system is this?
What is your configuration?
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Thanks for your reply Colin,
now its working fine, just checked couple of things on SCCM side.
