SSID sometimes dissapear
Hi All,
may I ask, why on my aruba wireless networking sometimes 1 SSID authentication base on 802.1x dissapear for 1 minute, then re-apear again,
whats happen on my aruba ? or where can i find the log ?
thank you.
Re: SSID sometimes dissapear
Does this happen to both bands?  Possible that there are radar events causing the 5GHz radio to cease transmission for a time whilst it checks a new channel.
Is it only happening to 1 x ssid or all?
ACCP, ACCX #817, ACMP, ACMX #294
just 1x ssid sir, another ssid still apear
Hudaya,
What are you using to see the SSID?  Sometimes if there is alot of congestion in the wireless spectrum, collisions would make an SSID seem like it has disappeared.  In addition, the device that is looking at the SSIDs could miss beacons based on its own scanning algorithm.  I have seen this mostly outdoors with alot of interference and with android devices.
its not ap outdoor sir, its indoor AP, we deploy IAP-215
and all customer disconnected for 1 minute
and this problem still happening sometimes.
still desperate why this problem still happen :(
We need more information.
What version of Instant?
How many SSIDs are you broadcasting?
What is the minimum and maximum transmit power of your access points?
Do you have Broadcast Filter ARP or Broadcast Filter all enabled?
Are clients on the 5ghz band also getting disconnected
- We deploy and convert instant to AP base sir,
- and at our site, we have controller 7010 with version 6.4.4.8,
- for SSID, we have 3 SSID,
1 simple ssid for director, 1 SSID using clearpass guest, 1 SSID using clearpass 802.1x,
- transmit power of AP is 12W, the AP's in cli, i type show ap database, and all AP still up, only SSID, sometime only 1 SSID disapear (SSID 802.1x), sometime all SSID gone.
- yes, all client getting disconnected
- you mean this one ?
Please open a TAC case so that they can get to the reason for your issue.
On the commandline of the controller, you should type "show log system all" or "show log wireless all" to see if there is any evidence of something that could be wrong..
