Security Questions for Self Registration
  • 1.  Security Questions for Self Registration
    Posted Jun 19, 2011 10:58 PM
    I set up some security questions with a drop drown on the securities question field. I use this field within the self registration section when a user wants to reset a password. Upon testing this I am able to select from the questions (user sees the drop down and questions) but when the user goes back in (say if they forgot their password) I am seeing the "key" used to set up the drop down instead of the "value" the question.
    Any idea how to force this to show the user the value/question instead of just a number/key like 1?
  • 2.  RE: Security Questions for Self Registration
    Posted Jun 20, 2011 12:05 AM
    You need to use the plain english name in the options list rather than the key 1.
    So instead of
    1 | What city where you born in?
    2 | What was the first car you owned?
    You use
    What city where you born in ? | What city where you born in?
    What was the first car you owned? | What was the first car you owned?
  • 3.  RE: Security Questions for Self Registration
    Posted Jun 21, 2011 08:44 AM
    Thanks Carlos that worked perfectly.
