Frequent Contributor II
TACACS Services Dictionary for Avaya switches
I am trying to set up TACACS authentication for management of our Avaya Switches.
When my enforcement policies are applied and a privilidge level is sent to the switch, all users, regardless of privilidge level are only getting read-only access.
I am using the "Shell" TACACS Service dictionary to send the priv-lvl service attribute.
I played with checking the "Enable to Permit Unmatched Commands" under the commands tab with the command list empty.
This gives rw access to all. even those at priv-lvl 1.
Not sure what to try next.
Re: TACACS Services Dictionary for Avaya switches
Curious if you ever got this resolved or working as I've run into the same issue.  Long shot given the date of the post, but worth asking.
