Frequent Contributor II
Trial key license for CP-VA-5k
Is there a trial key license I can use to activate a 5k system until I have the final code ?
Re: Trial key license for CP-VA-5k
You can request an eval key via MyNetworking Portal (https://www.hpe.com/networking/mynetworking), or contact your local Aruba partner or Aruba SE.
When registered and login go to register license and select a ClearPass 90-day eval (Lic-1-ClearPass). That should run for 90 days, and you can replace the key and subscription id when you have your production license.
Make sure you select the CP-VA-5K when deploying your VM.
Thank you, this is very helpful and allow me to more forward with the expansion on my cluster
I've installed two trial licenses on two 5k and they are showing 500 endpoint. Will this be an issue when I install the permanent 5k key ?
If the platform is deployed as 5K during installation, I don't expect any issues. That license shows only 500 is no problem and should change when you change the license to you production key.
Thank you for the details !
Sifus,
I'm using CP-SW-EVAL with the sizing of CP-5K and already have my production license activated. is there any issue if i continue using  CP-SW-EVAL? I dont want to do the morph because it asked me to add in another hard disk...
You need to use the correct specs for a 5K or it will not be supported.
Tim Cappalli | Aruba Security
