Tunnel Node controller aruba with comware switch
dear all,
can tunnel node applied in comware switch ?
such as 5130 series.
kindly need your advice
thankyou
Re: Tunnel Node controller aruba with comware switch
No. Tunneled-node is an Aruba switch feature.
Tim Cappalli | Aruba Security
noted sir,
thanks for quick response
