Tweet from @zebinsk
@ArubaNetworks Excellent video, very good. AppRF will could be used in 3x00 controllers?
Tweet from @ozwifi @zebinsk @ArubaNetworks Yes. ArubaOS 6.2 is compatible with 3000 and M3 series controllers as well. View on Web
From release note, NOT compatible with 3200 controller. Though, I would love to be mistaken about this.
G
3200 with the memory upgrade or 3200xm should be fine i believe.
Fantastic news....thought my 3200 was going to be an issue.
Memory upgrade order in progress!
Grant
Conflicting advice now...I have now been told a 3200 WITH memory upgrade will not support 6.2.x.x. OS, and have been told it WILL support it.
Anyone out there know for sure?
WILL. Let me check on the release notes...
UPDATE:
The release notes do not mention that the 3200 with the memory upgrade is supported. That language should make it into the next released release notes...
Just my lack of knowledge speaking, but that seems to indicate that the 3200XM (which IS supported with 6.2.x.x) is NOT the same as the 3200 with an added memory kit?
Taken from the 6.2.0.3 release notes,
ArubaOS 6.2.x is supported only on the newer MIPS controllers (7200 Series, M3, 3400, 3600, 600 Series,3200XM, and any 3200 controller with its memory upgraded using 3200-MEM-UG kit).
