Contributor I
Two SSIDs and guest portal
Hey everyone
I have two SSID on my Aruba Controllers with are directed to clearpass guest portal. This setup was working on a older setup with our 6003 controller. Now running 2x7220.
One of the SSIDs are going to be assigned to Endpoint:Guest Role ID=2 and the other to Endpoint:Guest Role ID=3.
This is because access is one day for ID=2 and one month for ID=3.
My problem now is that under computed attributes both values show ID=2.
The controllers are sending out the same groups for both SSIDs, are this were the Endpoint:Guest Role ID=2 are comming from ? Feel kind of stupid for not figuring this out )-:
Regards
Jon
Re: Two SSIDs and guest portal
Why not use a single SSID?
Tim Cappalli | Aruba Security
Contributor I
Guest are just using phone number and SMS code for authentication. How would I seperate them ?
Regards
Jon
