Moderator
UPDATED - ClearPass Profiling TechNote V1.2
Teams, I’ve UPDATED the Profiling TechNote adding in details of the features from the CPPM 6.5 release, such as TCP Fingerprinting, On-demand SUBNET scan, SNMP Updates and the framework we developed to allow administrator’s to perform custom device classification of unknown devices. Basically we allow admin’s to create custom rules for an endpoint using profiled attributes.
You can find the document on the support site located here ClearPass Profiling TechNote V1.2.pdf
Happy reading – go fill your boots..!!….. comments and feedback/suggestions graciously accepted.
Best Regards
-d
ClearPass Product Manager
Re: UPDATED - ClearPass Profiling TechNote V1.2
Thank you, always clear and helpful information.
ACMP, ACCP, BCNE
Satori Internetworking
http://www.net-satori.ca/
