Users using 802.1X can not connect to the wireless network
  • 1.  Users using 802.1X can not connect to the wireless network
    Posted Feb 10, 2012 12:17 PM
    Hi everyone;
    User using 802.1X can not connect to the wireless network and looking on the logs is showing the following message:
    <ERRS> |authmgr|  Dropping the radius packet for Station 00:21:6a:4f:f6:8c d8:c7:c8:11:05:91 doing 802.1x
    Thank you for your help
    Wilson
  • 2.  RE: Users using 802.1X can not connect to the wireless network
    Posted Feb 10, 2012 01:06 PM
    Please check the number of timeouts on the radius server using the following command
    "show aaa authentication-server radius statistics"
    Also, check the event viewer on the RADIUS server and see if Access-Request is making it to the server.
  • 3.  RE: Users using 802.1X can not connect to the wireless network
    Posted Feb 10, 2012 03:57 PM
    Hi Hthakker,
    I have issued the command "show aaa authentication-server radius statistics" is showing 48 timeout, but I have tested a ping from the controller to the radius server and it answer well. the user on LAN autheticate using the same Radius server and they don't have any problem.
    I appreciated if you have any other suggestion.
    Thanks for your help
    Wilson
  • 4.  RE: Users using 802.1X can not connect to the wireless network
    Posted Feb 13, 2012 10:36 AM
    Wison,
    Pick as user that is not able to authenticate and enable debugging for that particular user
    config terminal
    logging level debugging user-debug <user-mac>
    As mentioned in the previous post, it would be beneficial to look into the event viewer of the RADIUS server and check for the users that are not able to authenticate. The event viewer should have an event for authentication response.
    Also, as mentioned by Sathya, run the command "show auth-tracebuf" command that will show the sequence of steps for the user authentication.
  • 5.  RE: Users using 802.1X can not connect to the wireless network
    Posted Feb 10, 2012 03:59 PM
    Another command that would be useful is the "show auth-tracebuf" which will show you the deatils for the authentication process
    Sathya
