Virtual IP on management and Data Interface
Hi all
i have a plan to use data and management port on clearpass publisher, where data port is dmz port for guest portal, since my guest subnet is located on dmz, and management for internal communication (AD, clearpass subs). for HA, i want to ad VIP on both data and management port, but i found this on technote service routing :
"Since the release of CPPM 6.1.1 you can configure VIP addresses pairs concurrently across the Management and Data Interfaces. Prior to 6.1.1 if the server had both Management and Data VIP configured, then the VIP will only work with the data interfaces."
so i cannot use vip on management and data concurrently? any recent update? i am using clearpasss 6.6
thank you
Re: Virtual IP on management and Data Interface
 Yes, you can according to the technote. :)
Cheers
James
