Occasional Contributor I
Why does my IAP guest network keep making users enter in username and password?
I have IAP 215's with 2 SSID's set up. One is a guest network but it keeps asking my users, primarily iPhone users to re-enter the username and password after the phone's screen turns off. Is there a way to prevent the users from needing to relogin?
Re: Why does my IAP guest network keep making users enter in username and password?
Do you have ClearPass?
Tim Cappalli | Aruba Security
I am not sure. How do I find out?
Valarie Wiles
Information Technology Administrator
Strength of Nature Global, LLC
64 Ross Rd
Savannah, GA 31405
Office: 912-234-3700 Ext. 151
Direct: 912-544-0623
Mobile: 912-414-0313
Valarie.Wiles@songlobal.com
IT_Girl,
ClearPass would be an external radius server/guest access solution that you might have purchased.
MVP
IT_girl - Reason they ask is that this is most commonly solved by implementing MAC-authentication to avoid having to re-enter the username and passwords. Using a product like Clearpass for guest registration will also give you automatic MAC-address registration connected to the useraccount during that process. This in turn will provide you with an easy process for MAC-authentication and good userexperience.
Regards
John Solberg
-ACMX #316 :: ACCX #902 :: ACSA
Aruba Partner Ambassador
Intelecom/NetNordic - Norway
Remember to Kudo if a post helped you! || Problem Solved? Click "Accept as Solution" in a post!
I did not purchase clear pass then.
Valarie Wiles
64 Ross Rd
Savannah, GA 31405
IT_Girl,
It might be easier to just have a WPA2-PSK SSID for guests, then.
Is there not a fix for this?
Valarie Wiles
64 Ross Rd
Savannah, GA 31405
No you would need to have ClearPass in place.
Thank You,
Troy
Valarie Wiles
64 Ross Rd
Savannah, GA 31405
By default, a user on Aruba Instant will time out after 10 minutes of inactivity.  If you want to do something more creative, it will require an external policy server.
