Wildcard cert will not import without a passphrase
  • 1.  Wildcard cert will not import without a passphrase
    Posted Nov 15, 2017 12:03 PM
    I have a *.domain.com certificate for HTTPS that was generated without a passphrase to protect the private key.  ClearPass would not import it.
    Going through openssl to aes256 encrypt the private key with a passphrase worked in the command line, but ClearPass complained, something about the header being invalid.
    Is there any special signing requirements for being able to import the private key?
  • 2.  RE: Wildcard cert will not import without a passphrase
    Posted Nov 15, 2017 12:14 PM
    Did you try importing a plain text key?
  • 3.  RE: Wildcard cert will not import without a passphrase
    Posted Nov 15, 2017 12:39 PM
    Yes I've tried: when trying to import the plain-text private key without putting in the passphrase, ClearPass cert import section said "Private Key Password must be specified"
  • 4.  RE: Wildcard cert will not import without a passphrase
    Posted Nov 15, 2017 12:41 PM
    A tangential question which may help is: what is the internal SSL/Signing component that ClearPass uses?  Is it OpenSSL?  Maybe there are compatibility issues I could hunt down.
  • 5.  RE: Wildcard cert will not import without a passphrase
    Posted Nov 15, 2017 12:43 PM
    Yes, you need to specify a strong password during import. This will be used to protect the key if exported from the system.
  • 6.  RE: Wildcard cert will not import without a passphrase
    Posted Nov 15, 2017 12:50 PM
    Yes, I agree about the need for a private key being protected.  However, this private key - as supplied - is not.
    Importing the plain-text private key didn't work.  So I tried applying a passphrase.
    ClearPass didn't like the private key after I had it signed with the passphrase.
    So if there isn't a way around not using a passphrase, is there any guidance on the formatting or header requirements of the private key?
  • 7.  RE: Wildcard cert will not import without a passphrase
    Posted Nov 15, 2017 12:52 PM
    Don't apply a passphrase externally. Upload the clear text key and then enter a passphrase in the box.
  • 8.  RE: Wildcard cert will not import without a passphrase
    Posted Nov 15, 2017 01:34 PM
    When you do that, it says the "Private Key could not be loaded (password may not be correct)"
    I think I'll have to try and passphrase encrypt it again from CLI via openSSL.  I just wish I knew what ClearPass was looking for in the Private key.
  • 9.  RE: Wildcard cert will not import without a passphrase
    Posted Nov 15, 2017 06:21 PM
    ClearPass will accept a traditional PKCS#8 key or a PKCS#5 v2.0 encrypted private key (des3)
  • 10.  RE: Wildcard cert will not import without a passphrase
    Posted Nov 15, 2017 07:38 PM
    Thanks, that helps. I'll see if I can sort it out.
