Would token caching help with AP Roaming?
I seem to have roaming issues between AP's. I use 802.1x authentication and the clients seem to fail when trying to roam to another AP. Would token cacheing keep the clients from haveing to reauthenticate to each AP as they roam or am I understanding that wrong?
Thanks!
Re: Would token caching help with AP Roaming?
Are these APs attached to the same controller ?
Do you have the APs added to the same AP-Group ?
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Yes. Single Controller all in the default group. Mix of 105's, a 135, and some 225's
What type of devices are you using ? Windows , Apple, Android ?
What version OS are you using ? Do you have ClientMatch enabled?
Thank you
Victor Fabian
