certificate warning clearpass using http
Hello i want to use the captive portal but i dont want to  get the certificate warning, ill use http, and i know it goes on cleartext the password and user.
Anyways I have set it up that on clearpass on the selftregistration  on
Secure Login im putting send clearpass password cleartext http
on the controller on the captive portal authentication i put the checkbox i put the check on it also on the  login page i put http instead of https for the url
and when i use the captive portal im getting redirected but i get the certificate warning
Also i tried this
http://community.arubanetworks.com/t5/Technology-Blog/Captive-Portal-why-do-I-get-those-certificate-warnings/ba-p/268921
and i tried deleting the https rule that redirect but when i do that when iuse the captive portal i get stuck when i try to use a https page like google to po up the captive portal... if i use a page that use http then its okay it works but users will try to use google or something like that so this does not work for me...
I also see that the someone posted a mesage in that tread that noone asnwer to seems to be the same problem
TIM, someone!  help? :(
Cheers
Carlos
Alternetworks Corp
Re: certificate warning clearpass using http
Hi Carlos,
In Home » Configuration » Authentication page, uncheck the security box.
Security:
Require HTTPS for guest access
If checked, HTTP access by guests will be redirected to use HTTPS instead.
Pavan
If my post addrresses your query, give kudos:)
Pavan
If my post address your queries, give kudos and accept as solution!
i still get the certificate error....
Alternetworks Corp
Are you getting a certificate error when you go to a non-secured site like ebay.com?
Tim Cappalli | Aruba Security
its when i got to a secure page for example google.com
Alternetworks Corp
On clearpass this is also unchecked
Require HTTPS for guest access under Authentication Settings
Alternetworks Corp
The only way to prevent that would be to remove HTTPS redirection in your user-role.
If you mean deleting this rule
IPv4 user any svc-https dst-nat 8081 Low
I already did it and when i do that the https pages wont open...
Cheers
Carlos
Alternetworks Corp
That’s correct. There is no way to avoid certificate warnings when navigating to an HTTPS page. That’s the whole point of the certificate warning in the first place.
That works if the captive portal is the controller....
It doesnt work if the captive portal is the clearpass...
So there is no way to do this with the clearpass? even using http only?
It just that i find odd that you can do it with controller but not with clearpass..
Alternetworks Corp
