Valued Contributor I
clearpass regular expressions
I've got a clearpass service that is used to authenticate our eduroam users against our AD service.
Amongst other things service selection is done by checking that radius:ietf:User-Name contains @york.ac.uk which is our standard eduroam realm.
AD authentication is set up to strip off the @york.ac.uk suffic and also , if present to remove our AD domain prefix (ITSYORK)
I thought that I could use match_regex specifying
@york\.ac\.uk$|^ITSYORK
to select the service based upon the User-Name  is but the above doesn't work. What should I be specifying?
Rgds
Alex
Re: clearpass regular expressions
I usually just do
Authentication:Full Username             ENDS_WITH       @york.ac.uk
You don't want to allow DOMAIN\ on eduroam. It is not valid and users will not be able to connect at other universities.
Take a look here at how you can work around this:
http://community.arubanetworks.com/t5/Mobility-Hero-Tutorials/AD-Machine-Auth-Eduroam-ClearPass-Jan-2014/
Tim Cappalli | Aruba Security
