create a portal for disable user in enpoint db
  • 1.  create a portal for disable user in enpoint db
    Posted Apr 30, 2014 11:30 AM
    hello
    ii need create a portal for disable user in enpoint db
    can you help me
  • 2.  RE: create a portal for disable user in enpoint db
    Posted May 02, 2014 12:19 AM
    jujusas,
    If you already have a captive portal configured on clearpass, you are already sending back rejections to users who do not pass authentication.  Your only option is to:
    1.  Create an HTML page on the Aruba Controller , or ClearPass with your message
    2.  Create a Captive Portal Authentication profile on the Aruba Controller that has the URL of the controller's or the ClearPass page as the "Login Page" URL
    3.  Create a role that has the Captive Portal ACL attached and configure the Captive Portal Authentication profile as the profile you created in step 2
    4.  When your users fail authentication in ClearPass, send back an "accept" in the enforcement profile but also send back and Aruba-User-Role VSA as the name of the role you created in step 3 on the controller.
    When the user opens up a browser to see what happened, they will get the reject page you created in step#1.  Not pretty and there are better ways to do it, but this is just to get you started.
