iOS Device Reconnect Post Provisioning
Having some issues where some apple ios devices are getting an error message (attached) on the post provisioning page when attempting auto reconnect.  It doesn't seem to be related to any particular phone model or ios version.  Same results when using the manual reconnect.  Note:  I blocked out some areas of the screenshot.  Thoughts?
Aruba
Re: iOS Device Reconnect Post Provisioning
Check the application log - you might find some more clues as to why it is failing in there.
no failures in the application log or access tracker.  The device is successfully connecting however the error message on the page says it's failing
found this in the app log when debug was on:
Failed to issue the RADIUS disconnect request for auto-connect
Script:    /guest/mdps_profile.php
Function:  NwaMdpsProfileDoDisconnect
Details:   (
  'result' => (
    'error' => 1,
    'message' => 'Could not retrieve profile values (1)',
2 things
1. First make sure you have COA and Aruba selected as the vendor in CPPM
2. Make sure you check mark the Add switch IP address in the redirection URL in the captive portal settings in the controller.
Thank You,
Troy
