Contributor I
pushing proxy setting through Guest SSID
Our edge point with ISP is windows ISA server(10.10.10.10), so the user should have correct LAN setting to get internet browsing
With domain users I’ve created GPO to push the LAN setting
For the Guest users I’ve tried to do it with Guest SSID as below
Configuration > security > authentication > L3 authentication > Guest-captiveportal-profile > Proxy Server Configuration as (10.10.10.10:8080)
But the guests users does not taking this setting after connecting to Guest SSID,
Now I have to write the LAN setting manually to get internet browsing
can someone help please ?
M. Alajeely
Re: pushing proxy setting through Guest SSID
Hi Alajeely,
I'd suggest having a look at the following post with the aim of configuring DHCP on the controller to deploy a proxy PAC file which will automatically configure your guests proxy settings.
However, this isn't a configuration I'd recommend unless there are no alternatives. Ideally I'd setup a transparent proxy then destination NAT HTTP and HTTPS traffic to the transparent proxy. This solution works with any client machine.
The above proxy PAC solution can be problematic with some browsers accepting the PAC settings and others seemingly ignoring it.
James
Cheers
James
Contributor I
Hi
the first solution does not work with me, the captive porter window disrepair totally and the guest can not get it anymore.
can you give me more details about the second solution please
(Ideally I'd setup a transparent proxy then destination NAT HTTP and HTTPS traffic to the transparent proxy. This solution works with any client machine)
with steps please
Alajeely
M. Alajeely
Regular Contributor II
