switch DLINK - AAA CPPM
  • 1.  switch DLINK - AAA CPPM
    Posted Mar 21, 2014 07:37 AM
    Hii,
    It is possible use CPPM with switches DLINK?
    I have a problem. I´m not sure: Do i need a RADIUS diccionary DLINK to import in CPPM? or Can i use the IETF diccionary?
    Thank you very much
  • 2.  RE: switch DLINK - AAA CPPM
    Posted Mar 21, 2014 07:51 AM
    It depends on:
    - Which model Dlink switch do you have (does it support radius?)
    - What functionality do you want with CPPM.
  • 3.  RE: switch DLINK - AAA CPPM
    Posted Mar 21, 2014 08:02 AM
    The switch models:
    DGS 1210-48 y DGS 1210-2
    I tried to authenticate by 802.1x on switch port. (user/pass). But the customer have a some problems. I used the IEFT diccionary.. but i want importe the diccionary Radius DLINk..
    I created a xml but i can not importe
    But the CPPM
     File contains invalid XML tags. Try export to see the valid XML tags
    It is good??
  • 4.  RE: switch DLINK - AAA CPPM
    Posted Mar 21, 2014 08:51 AM
    What is the problem they are having?   The switch supports RADIUS, so the standard RADIUS dictionary file should for work for access-accept and denies and other standards based features.    Are you looking to implement something more specific that is DLINK specific?
  • 5.  RE: switch DLINK - AAA CPPM
    Posted Mar 21, 2014 08:57 AM
    We've configured to use the IETF standard but the partner said that I could not see any input or output in the tracker. But now .. a few minutes ago, told me you can already see in the tracker logs.
    Bad switch configuration
    Thanks for your help.
