two factor authentication with Clearpass
This thread has been viewed 30 times
  • 1.  two factor authentication with Clearpass
    Posted Aug 23, 2017 08:42 AM
    Is it possible to do 2 factor authentication in Clearpass i.e access with user credentials as well as token based password?
    Right now, I am able to do it either with user credentials or with token based password.
  • 2.  RE: two factor authentication with Clearpass
    Posted Aug 23, 2017 09:04 AM
    Yes, you can use the Token Server authentication source with third party MFA solutions.
  • 3.  RE: two factor authentication with Clearpass
    Posted Aug 24, 2017 09:09 AM
    Is that just for web portal type auth requests or would it work for eap based wpa2-enterprise auths as well ?
    Any documentation as to how to implement 2FA?
    Rgds
    Alex
  • 4.  RE: two factor authentication with Clearpass
    Posted Aug 24, 2017 09:15 AM
    You really don't want to get into MFA at the supplicant level using RADIUS. It's messy and is a terrible user experience.
    You can use API-based MFA as part of an 802.1X sandwich flow. We've only tested DUO and GoVerifyID.
    Unfortunately I haven't had a chance to write it up as there has been very little demand.
  • 5.  RE: two factor authentication with Clearpass
    Posted Aug 24, 2017 09:20 AM
    I've just set up a LINOTP box, primarily for our StrongSwan VPN  dev service which should provide similar functionaliy to the DUO setup.
    A
  • 6.  RE: two factor authentication with Clearpass
    Posted May 09, 2018 08:09 PM
    I need to setup a demo of ClearPass with Imageware biometric authentication, but without documentation, it seems I can't join the dots of the configuration steps. Anyone to help on this?
  • 7.  RE: two factor authentication with Clearpass
    Posted Aug 24, 2017 10:42 AM
    I have setup OpenOtp as my Token server
    I created a service in CPPM with authentication source as Openotp token server and once I enable LDAP as well as OTP for a user in token server CPPM shows rejected.
    In packet capture logs I saw OpenOtp is asking for token password once LDAP password is authenticated but CPPM is not asking for token password
  • 8.  RE: two factor authentication with Clearpass
    Posted Aug 29, 2017 01:43 AM
    Can clearpass be configured to respond to access-challenge response from token server?? How can CPPM provide token password to the token server
