Frequent Contributor II
visualRF overlay not working
I have a customer running 8.0.6.2. He is using visualRF to map all his locations. All the maps are working fine except one. On this map, none of the overlays will produce a picture. Heatmap, Client Health, etc will not display a image.
Anyone seen this problem or have something I can try?
The scale is correct and I added a region just in case but nothing changed.
when selecting an overlay, it does show the progress bar like its producing the image.
I've tried Firefox and IE browsers.
Re: visualRF overlay not working
I've fixed this by restarting the VisualRF engine.
Tim Cappalli | Aruba Security
Thanks, that worked!
Contributor I
We are experiencing this same issue on Visual RF 8.0.7.1 also.  We restarted Visual RF and still can't see the asset tags.  They have several buildings and floors and all are on the same controller.  It's only one floor that we are unable to view the overlay of Aeroscout tags.  Anyone else seen this?
