what is difference between onboard and quickconnect?
quickconnect only support 802.1x setting configuration?
onboard In addition to support 802.1x setting configuration also supports PSK setting configuration?
Re: what is difference between onboard and quickconnect?
QuickConnect standalone is used to configure network settings for users. It can be purchased independently from ClearPass.
Onboard issues unique certificates to each device. Onboard uses QuickConnect as part of that process.
Tim Cappalli | Aruba Security
