whatsapp and CPPM / whatsapp connection after http navegation
Hi.
I would like to share with you this behavior, guest are avaible to connect to network (a as espected) using smartphone but whatsapp doesnt connect until guest navegate on internet using a browser, if guest dont navegate on Internet the whatsapp dont connect.
guest conection to network > connection whatsapp (faild)
but
guest connection to network > browser navegation > connection whatsapp (work)
i dont have any policy in order to block whatsapp port. I think the device must navegate on internet in order to get full access to the other apps.
If possible change this behavor?
best regard.
Re: whatsapp and CPPM / whatsapp connection after http navegation
Are your guests in a pre-authentication role?
Tim Cappalli | Aruba Security
guest are in guest role (authenticated)
Please open a TAC case.
