Training, Certification & Career
Contributor I
How to create step by step Ap group, virtual ap, SSID manually?
Hello to every one. I recentely took the ACMA (I am really happy). I have been studied by my self, However, I follow the lab book.
I always provisioned "create" a new Network/SSID just following thw WLAN/LAN Wizard wich was pretty much easy to understand, but just for learned purposes, I want to the same thing as the wizard does but manually and by my self.
I start to do it, but then I get lost :(
Could you guys help me on it please?
Community Manager
Re: How to create step by step Ap group, virtual ap, SSID manually?
One thing you can do, is run through another wizard. Then when you complete the wizard look over the summary. you can open the GUI in another wizard the start working. When you get stumped you can check the summary from the wizard to get back on track.
Airheads Community - The best place to Connect. Engage. and Learn.
Contributor I
I will try it. One thing that I really get lost is on AAA.
I'll post it here soon.
Community Manager
Another method you can do is:
Still do the wizard-
At the summary click the link"Commands to be pushed" this will show you all of the configurations you will need to do. you can then copy this and drop it in a note somewhere and you can then do a step by step manual network configuration.
Contributor I
I did not find the CLI command used, Look:
Community Manager
OH!!
I see your using a 200. The options I suggested were based off of later versions of code. Here is what I had mentioned. Ill send you the CLI list
Contributor I
Oh!
Now I can see, I didn't realize it so far. Well, I will try to do it in one controller running 6.4 firmware and check what would be the step by step on CLI. However, with your help, I was able to configured what  wanna to.
Thank you so much for your help Jamie. :)
Frequent Contributor II
Can I create AP group from AP wizard?
Community Manager
Yes, see below
Is it WLAN wizard or AP wizard
