ArubaOS DHCP Fingerprinting
Community Administrator
This guide focuses on configuration of DHCP fingerprinting, which is used in conjunction with user roles on the Aruba Mobility Controller. When a user authenticates, their device type is taken into account. Based on that device type, a new role can be assigned to the device, such as restricting access to certain protocols or completely blocking access.
Download here:
Version history
Revision #:
4 of 4
Last update:
‎08-05-2015 11:30 AM
Updated by:
Labels (1)
Contributors
Comments
brianrpsgt1@gmail.com
Are DHCP Options 12, 55, 60 and 81 the only options available to select?  The document refers to them as 'typical values'.  Wondering if there are other selectable DHCP Options, such as DHCP Option 61 - Client Identifier.
Thanks for any assistance.
