Campus Network Design
Super Contributor II
This guide covers the deployment of Aruba WLAN in a typical campus network, and it is considered part of the base designs guides within the VRD core technologies series. This guide covers the design recommendations for a campus deployment and it explains the various configurations needed to implement the Aruba secure, high-performance, multimedia grade WLAN solution in large campuses.
Version history
Revision #:
9 of 9
Last update:
‎03-31-2016 07:54 AM
Updated by:
Labels (1)
Contributors
Comments
Asif Iqbal
nice
Steve Snodgrass
Great doc, but any chance it will be updated for 6.4?  The redundancy sections are rather dated now.
rodrigues
Can anyone give me an answer or point me to the "VRD Campus Networks" documentation for the following questions:
"VLANs are used on the access side of the controller where the APs terminate their GRE tunnels. These VLANs carry traffic back and forth between APs and the controllers. Aruba strongly recommends that edge access VLANs should not be dedicated to APs. The only exception where the APs may have to be deployed on dedicated VLANs is in environments where 802.1X is a requirement on the wired edge. The APs should use the existing edge VLANs as long as they have the ability to reach the mobility controller. Deploying the APs and AMs in the existing VLANs allows for the full use of the Aruba rogue detection capabilities."
Should the AP's be in their own vlan or in the same vlan as clients?
Steve Snodgrass
 Hi Steve, The redundancy part of this document has been updated independently now. It is available here
pcasanave
Any chance of getting an AOS8.2 revision with MM integration and control?
