Campus Redundancy Model
Community Manager
Community Manager
In centralized Aruba WLAN deployments, the mobility controller is the heart of the network. The controller operates as a stand-alone master, or in a master-local cluster. Aruba provides several redundancy models for deploying mobility controllers. Each of these options, including the choice to forgo redundancy, must be understood so that the correct choice can be made for each deployment model.
Version history
Revision #:
5 of 5
Last update:
‎07-23-2015 11:22 AM
Updated by:
Labels (1)
Contributors
Comments
Steffen
Hello
is there an updated Guide with the new feature, HA? If not, when is it available?
Steffen
