Campus WLAN Redundancy
Community Administrator
Version history
Revision #:
2 of 2
Last update:
‎02-13-2017 03:42 PM
Updated by:
Labels (4)
Contributors
Comments
Airbud
 Thank you for another helpful VRD. Looking at pages 95 - 99 a Master / Local (HA Active / Active and Active / Standby scenario). I do not see any infomration provided on the expected tunnel action when the LMS becomes reachable.
In an Active Active(or Standby) HA should the AP switch from the backup LMS to the primary LMS with the reestabilished reachability of the primary LMS(I am assuming the AP is able to establish this with a heartbeat) or will it just build a standby tunnel?
Thierry Lubbers
Does anyone know when a ArubaOS 8 version of this document will be added?
