Validated Reference Design Guides
Outdoor MIMO Wireless Networks
This Solution Guide is designed to help customers understand the Aruba system architecture and the individual components that are needed to deliver reliable, high-capacity outdoor networks using 802.11n with multiple-in and multiple-out (MIMO) radios. Aruba has extensive experience designing complex outdoor WLAN solutions for applications like stadiums, outdoor transportation terminals, oil and gas facilities, municipalities, and large campus environments. This guide describes the lifecycle of an outdoor MIMO wireless network deployment; typical basic processes and tools that are used in outdoor wireless networking; MIMO antenna selection and placement for maximum capacity; design recommendations for common deployment scenarios; and much more.
Version History
Revision #:
9 of 9
Last update:
‎11-05-2015 07:04 AM
Updated by:
Labels (1)
Contributors
Comments
MVP MVP
The PDF version cannot be found. FYI
Is this a frequent problem?
Request an official Aruba knowledge base article to be written by our experts.
