Validated Reference Design Guides
Outdoor Point-to-Point Deployments
Point-to-point (PTP) wireless connections have many use cases including linking buildings on university campus, creating connections between offshore oil rigs, and eliminating the need to pull fiber cable between buildings on opposite sides of a busy road. This guide will help you select the right hardware platform (including both the AOS-based AP-175 and Aruba¹s new AirMesh products; Choose appropriate antennas and accessories; Identify and overcome some of the most common outdoor installation challenges; Set up and configure the Aruba solution.
AP_OutdoorPointToPoint.pdf (3,243 KB)
Version history
Revision #:
6 of 6
Last update:
‎07-29-2015 11:09 AM
Updated by:
Labels (1)
Comments
Upstanding_Citizen
Please fix your links! They go to "page not found"
 Can someone please post a valid link to the PDF version of the Outdoor point-to-point deployment guide?
Lots of 404 errors with dead links.
MVP MVP
I have alerted a moderator, but the appropriate link is http://arubanetworks.com/wp-content/uploads/AP_OutdoorPointToPoint.pdf
Is this a frequent problem?
Request an official Aruba knowledge base article to be written by our experts.
