Single VLAN Architecture for WLAN
Community Administrator
With the launch of mobile devices in 2007, the use of Wi-Fi increased exponentially. To support increased number of clients on wireless Local Area Network (WLAN), network administrators started adding more VLANs with smaller subnet size for wireless clients, and VLAN Pooling became popular concept. Today, the requirement from WLAN has changed quite a bit compared to a decade ago. Increased use of IPv6 and large number of mobile devices roaming across the campus has increased the complexity of WLAN design.
Rather than using conventional design with VLAN Pooling and multiple smaller subnets, we think that there is a better way to design WLAN today using “Single VLAN with One Large Subnet" to serve all the wireless clients connecting to an SSID. This paper explains how we came to this conclusion
Version history
Revision #:
5 of 5
Last update:
‎01-25-2016 11:39 AM
Updated by:
Labels (2)
Contributors
Comments
The PDF file is tittled "Lync Over Aruba WiFi Validated Reference Design"
Hi kell490,
I just downloaded the file and it says "Single VLAN Architecture for WLAN". Can you try again using the link http://community.arubanetworks.com/aruba/attachments/aruba/Aruba-VRDs/74/1/Single%20VLAN%20Architecture%20for%20WLAN.pdf to download again?
Rahul Desai
Aruba Networks
Were you able to get the right VRD?
I too downloaded and indeed it is Single VLAN. If you cant get it let me know and ill get it to you.
The free epub for this available here
https://hpepress.hpe.com/catalog/Networking-98
