Wired Intelligent Edge
Aruba 2930F - can't ping from cli
  • 1.  Aruba 2930F - can't ping from cli
    Posted Aug 05, 2018 04:23 PM
    Hi Folks
    Few days ago i bought Aruba 2930F and I have a problem I'm not able to ping host in internet exp cnn.com from switch CLI
    PC connected to vlan 2 untagged port can ping internet host without any problem
    Switch is rechable prom subnet 10.0.0.0/23
    See config below:
    trunk 48 trk1 trunk
    timesync ntp
    ntp server 158.75.5.245
    ntp enable
    time timezone 60
    ip default-gateway 10.0.0.1
    ip dns server-address priority 1 8.8.8.8
    interface 48
    name "TRUNK_IN"
    exit
    snmp-server community "public" unrestricted
    vlan 1
    name "DEFAULT_VLAN"
    no untagged 38-47
    untagged 1-37,49-52
    tagged Trk1
    no ip address
    exit
    vlan 2
    name "Main vlan"
    untagged 38-46
    tagged Trk1
    ip address 10.0.0.249 255.255.254.0
    jumbo
    exit
    primary-vlan 2
    spanning-tree Trk1 priority 4
  • 2.  RE: Aruba 2930F - can't ping from cli
    Posted Aug 06, 2018 02:28 AM
    Does your PC gets an IP address from DHCP server? If so can you verify what the IP information (IP address, subnet, default gateway) the PC receives?
  • 3.  RE: Aruba 2930F - can't ping from cli
    Posted Aug 06, 2018 02:42 AM
    Hi
    My pc obtain IP via dhcp from server 10.0.0.1
    and working fine with the following setting
    IP 10.0.0.35
    mask 255.255.254.0
    gw 10.0.0.1
    DNS1 10.0.0.1
    dns2 8.8.8.8
  • 4.  RE: Aruba 2930F - can't ping from cli
    Posted Aug 06, 2018 10:48 AM
    Thank you very much. My feeling is that you also have ip routing enables but I can't see the config. This is not a problem but can you remove the ip default-gateway configuration line and add the following:
    ip route 0.0.0.0 0.0.0.0 <default gateway IP>
    ip routing (but think you have this already enabled)
    Now you can test again but think this will work.
    Regards, dobias
  • 5.  RE: Aruba 2930F - can't ping from cli
    Posted Aug 07, 2018 01:31 AM
    I already tried config with ip routing with the same results
    What is strange I can see that when i try to ping from pc i see on router nornmal response package
    but when I do the same from switch I see no answer
    3.JPGany sugesstion  ???
    I already tried difrent serwer subnets gatway and every time the same
  • 6.  RE: Aruba 2930F - can't ping from cli
    Posted Aug 07, 2018 03:23 AM
    if your switch can ping aother l3 devices on same segments , but cant ping to behind to your GW - it must be routing issue .
    From your switch to your GW , are u able to ping via CLI?
    Please share with us full switch config , and also output of traceroute to diffrent internet ips
  • 7.  RE: Aruba 2930F - can't ping from cli
    Posted Aug 13, 2018 04:58 AM
    Hi again
    I agree that seems to be routing releated
    I'm able to ping my switch from Aruba(10.0.0.249) - to GW(10.0.0.1) and from GW to Aruba.
    any other device connected to the same network are able to ping host in internet without any problems.
    I noticed that ICMP packet from Aruba lenght is 60 from other host 74
