Wired Intelligent Edge
HPE and Aruba Switch
  • 1.  HPE and Aruba Switch
    Posted Sep 17, 2018 05:31 AM
    Which core swich has configurable routing with HPE and Aruba Portfolio?
  • 2.  RE: HPE and Aruba Switch
    MVP GURU
    Posted Sep 17, 2018 07:16 AM
    What do you need ? (Type of Port / Speed / Modular ?)
  • 3.  RE: HPE and Aruba Switch
    Posted Sep 17, 2018 07:50 AM
    Need a layer 3 fixed 24 port swtich with 10 gbe
  • 4.  RE: HPE and Aruba Switch
    MVP GURU
    Posted Sep 17, 2018 08:52 AM
    24 Ports Gbe ? (SFP or Copper ?)
  • 5.  RE: HPE and Aruba Switch
    Posted Sep 18, 2018 03:54 AM
    SFP
  • 6.  RE: HPE and Aruba Switch
    Posted Sep 17, 2018 11:36 AM
    Greetings!
    Just for clarification: what sort of L3 routing protocol support are you looking for, and when you say 10GbE, do you mean all ports are 10G, or just 10G uplinks?
  • 7.  RE: HPE and Aruba Switch
    Posted Sep 18, 2018 03:55 AM
    All ports are 10G
  • 8.  RE: HPE and Aruba Switch
    MVP GURU
    Posted Sep 18, 2018 06:01 AM
    You can use 3810m 16sfp+ (with 2 slot with 4 SFP+) or 5400R with line card using SFP+ (like Aruba 8-port 1G/10GbE SFP+)
    With 3810, it is possible to have stack and with 5400zl, there is possible to have multiple management module and also use VSF
  • 9.  RE: HPE and Aruba Switch
    Posted Sep 18, 2018 06:10 AM
    Hello Alagoutte,
    Thank you for your suggestion.
    Do the below switches qualify as core swtiches for an fast growing smb with 300 employees?
  • 10.  RE: HPE and Aruba Switch
    MVP GURU
    Posted Sep 18, 2018 06:11 AM
    Yes !
