How to: Configure Authentication on Mobility Access Switches
Community Manager
Community Manager
The following steps are required to enable port authentication:
Configuration radius sever
user internal radius server
(ArubaS3500) #local-userdb add username test password test123 role authenticated
For MAC authentication, put the MAC address on the device as username/password in the local database.
user external radius server
 (ArubaS3500) (config) #aaa authentication-server radius acs
 ArubaS3500-24P-US) (RADIUS Server "acs") #host ?
 <host>                  IP address/Hostname of radius server
 (ArubaS3500) (RADIUS Server "acs") #host 10.4.135.132
 (ArubaS3500) (RADIUS Server "acs") #key test
In the external radius server, Both MAS IP and Shared key need to be added. The username/password need to be added in the external radius database.
Configure authentication server group
These are the configurable parameters
(ArubaS3500) (Server Group "test") #?
allow-fail-through      Allow authentication fail through
auth-server             Assign authentication server
clone                   Copy data from another Server Group
no                      Delete Command
set                     Configure rules to derive Role/VLAN
The followings are two examples:
Internal server is used:
There is a predefined server group "internal"
External server is used
(ArubaS3500) (config) #aaa server-group acs
(ArubaS3500) (Server Group "acs") #auth-server acs
Configure user role
In aaa profile, initial role and autnentication default role need to be specified. In the user role, the user vlan, the access-list, voip-profile, qos-profile policer-porfile and reauthnetication-interval can be customized:
(ArubaS3500) (config) #user-role test
(ArubaS3500) (config-role) #?
access-list             Apply access-lists to the role
no                      Delete Command
policer-profile         Apply Policer Profile to this role
qos-profile             Apply QoS Profile to this role
reauthentication-inte.. Configure reauthentication interval time
vlan                    Assign VLAN
voip-profile            Apply VoIP Profile to this role
For example:
(ArubaS3500) (config-role) #vlan 100
(ArubaS3500) (config-role) #access-list stateless allowall-stateless
Configure the authentication profile
The port can be configured to perform MAC authentication only, DOT1x authentication only or both MAC and DOT1x authentications. To enable MAC autnentication, MAC authentication profile need to be spcified, TO enable DOT1x authentication, DOT1x authnetication profile need to be specified in the aaa profile.
The following parameters can be customized for MAC authentication:
(ArubaS3500) (config) #aaa authentication MAC test-mac
(ArubaS3500) (MAC Authentication Profile "test-mac") #?
case Case of MAC string for authentication
clone Copy data from another MAC Authentication Profile
delimiter Delimiter in MAC string for authentication
max-authentication-fa.. Maximum auth failures before user is blacklisted. Range: 0-1. Default: 0.
no Delete Command
For example:
(ArubaS3500) (config) #aaa authentication mac test-mac
(ArubaS3500) (MAC Authentication Profile "test-mac") #delimiter colon
For DOT1x authentication
The following parameters can be customized for DOT1x authentication:
(ArubaS3500) (config) #aaa authentication dot1x test-dot1x
(ArubaS3500) (802.1X Authentication Profile "test-dot1x") #?
ca-cert                 CA Certificate for Client Certificate Verification
cert-cn-lookup          Check certificate common name against AAA server. Default is disabled.
clone                   Copy data from another 802.1X Authentication Profile
eapol-logoff            Handle EAPOL-Logoff.Default is disabled
framed-mtu              Set the Framed-MTU attribute sent to the authentication server
heldstate-bypass-coun.. Set the maximum number of times station can send bad user credentials and avoid going to held state by sending an EAPOL-Start
ignore-eap-id-match     Ignore EAP ID during negotiation.Default is disabled
ignore-eapolstart-aft.. Ignore EAPOl-START after authentication.Default is disabled
machine-authentication  Configure Machine Authentication Parameters
max-authentication-fa.. Maximum Number of Authentication Failures after which station is blacklisted. Range: 0-5. Default: 0.
max-requests            Set maximum number of times Id-Requests is sent to the station
no                      Delete Command
reauth-max              Set maximum number of times Id-Requests is sent to the station
reauthentication        Enable or Disable Reauthentication.Default is disabled
server                  Set authentication server parameters
server-cert             Server Certificate for EAP termination
termination             Configure Dot1x Termination Parameters
timer                   Configure state machine timers
tls-guest-access        Enable guest access for users with valid certificate.Default is disabled
tls-guest-role          Assign TLS Guest role
Foe example:
(ArubaS3500) (802.1X Authentication Profile "test-dot1x") #termination enable
Configure aaa profile to use MAC authentication or DOT1x authentication
The folllowing parameters can be customized or configured in aaa profile:
(ArubaS3500) (config) #aaa profile port-auth
(ArubaS3500) (AAA Profile "port-auth") #?
auth-failure-blacklis.. Amount of time to blacklist a STA if it fails repeated authentications. In seconds. 0 blocks indefinitely.
authentication-dot1x    Configure 802.1X authentication profile
authentication-mac      Configure MAC authentication profile
clone                   Copy data from another AAA Profile
dot1x-default-role      Assign default role
dot1x-server-group      802.1X authentication server group
enforce-dhcp            Require IP address to be obtained using DHCP
initial-role            Role that is assigned to a user before authentication takes place
mac-default-role        Assign MAC Auth default role
mac-server-group        MAC authentication server group
no                      Delete Command
radius-accounting       Configure server group for radius accounting
radius-interim-accoun.. Send RADIUS interim accounting records
user-derivation-rules   Apply profile to derive VLAN/Role from user atributes
xml-api-server          Configure XML API server
To enable DOT1x authentication, DOT1x authnetication profile need to be specified in the aaa profile.
The following cases are three examples:
Only enable MAC authentication
(ArubaS3500) (AAA Profile "port-auth") #initial-role logon
(ArubaS3500) (AAA Profile "port-auth") #authentication-mac test-mac
(ArubaS3500) (AAA Profile "port-auth") #mac-server-group acs
(ArubaS3500) (AAA Profile "port-auth") #mac-default-role authenticated
Only enable DOT1x authentication
(ArubaS3500) (AAA Profile "port-auth") #authentication-dot1x test-dot1x
(ArubaS3500) (AAA Profile "port-auth") #dot1x-default-role authenticated
(ArubaS3500) (AAA Profile "port-auth") #dot1x-server-group acs
(ArubaS3500) (AAA Profile "port-auth") #exit
Enable both MAC and DOT1x authentication
(ArubaS3500) (AAA Profile "port-auth") #mac-default-role test
(ArubaS3500) (AAA Profile "port-auth") #mac-server-group default
Bind the aaa profile to the port or port group
Apply the aaa profile in a port:
(ArubaS3500) (config) #interface gigabitethernet 0/0/1
(ArubaS3500) (gigabitethernet "0/0/1") #no trusted port
(ArubaS3500) (gigabitethernet "0/0/1") #aaa-profile port-auth
(ArubaS3500) (gigabitethernet "0/0/1") #exit
Apply the aaa profile in a port group:
(ArubaS3500) (config) #interface-group gigabitethernet port-auth
(ArubaS3500) (gigabitethernet "port-auth") #apply-to 0/0/45-0/0/47
(ArubaS3500) (gigabitethernet "port-auth") #no trusted port
(ArubaS3500) (gigabitethernet "port-auth") #aaa-profile port-auth
Fail-Open on MAS:
In terms of "fail-open" behavior when the authentication server is not available, this functionality is currently not supported. There are, however, some workarounds that can be implemented depending on the authentication requirement(s):
1. You can have more than 1 auth server in the server group for better availability, so if first server fails, it will try the next one, etc.
2. You can modify the logon role so it can be placed into a specific VLAN in such case, though this has obvious potential drawbacks
3. You can add MAC auth in addition to 802.1X so the client can still be authenticated in such case   (using different/local server)
In terms of modifying the logon role, additional role can be placed for "auth-FAIL" scenario:
If RADIUS server active –
    If auth pass then RADIUS replies role-A
    If auth failed then RADIUS replies role-B
If RADIUS server in active
   Role-C (actually we use logon role here)
The auth server needs to reply a role-B even when auth failed.
Version history
Revision #:
1 of 1
Last update:
‎09-25-2014 12:15 PM
Updated by:
Labels (1)
Contributors
Comments
You can fail-open when AAA servers are unavailable by using the unreachable-role.
(AAA Profile "zTest") #unreachable-role allowall
