How to configure DHCP Snooping functionality in Aruba MAS
The following command adds a static binding on a VLAN:
(host) ("vlan id") #dhcp-snooping-database <mac> gigabitethernet <slot/module/port> <ip_address>
The following command deletes a static binding on a VLAN:
(host) ("vlan id") #no dhcp-snooping-database <mac> gigabitethernet <slot/module/port> <ip_address>
The following command enables and configures DHCP snooping and static binding on a VLAN:
(host) (“vlan id”)# vlan-profile dhcp-snooping-profile <profile-name>
(host) (dhcp-snooping-profile “profile-name”)# enable
The following command attaches DHCP Snooping profile on the VLAN:
(host) (“vlan id”)# dhcp-snooping-profile <profile name>
Network Topology : DHCP Snooping function is enabled at a vlan level
The following example enables and configures DHCP Snooping on a VLAN:
(host) (“vlan 6”)# vlan-proifile dhcp-snooping-profile DHCP
(host) (dhcp-snooping-profile “DHCP”)# enable
 The following example attaches DHCP Snooping profile on the VLAN:
(host) (“vlan 6”)# dhcp-snooping-profile DHCP
Here's how we can verify if we have configured DHCP snooping in the manner suggested in this KB Article,
The following command displays the DHCP Snooping configuration details:
(host) (config) #show vlan-profile dhcp-snooping-profile DHCP
dhcp-snooping-profile "DHCP"
Parameter Value
DHCP Snooping Enabled
The following command displays the DHCP Snooping database details:
(host) (config) #show dhcp-snooping-database vlan 6
Total DHCP Snoop Entries : 3
Learnt Entries : 1, Static Entries : 2
DHCP Snoop Table
MAC IP BINDING-STATE LEASE-TIME VLAN-ID INTERFACE
00:00:00:60:4a:69 6.6.6.10 Dynamic entry 2013-09-06 10:50:05 (PST) 6 gigabitethernet1/0/2
00:00:11:22:44:55 4.4.4.4 Static entry No lease time 6 gigabitethernet1/0/2
00:00:11:33:66:77 7.7.7.7 Static entry No lease time 6 gigabitethernet1/0/11
The following command displays static entries of DHCP Snooping database:
Total DHCP Snoop Entries : 4
Learnt Entries : 0, Static Entries : 4
DHCP Snoop Table
00:00:11:51:77:11 7.7.7.7 Static entry No lease time 3 gigabitethernet0/0/4
00:00:77:11:66:33 6.6.6.6 Static entry No lease time 3 gigabitethernet0/0/4
00:11:77:22:88:22 9.9.9.9 Static entry No lease time 6 gigabitethernet1/0/4
Version history
Revision #:
1 of 1
Last update:
‎11-04-2014 01:13 PM
Updated by:
Labels (1)
Contributors
