Wired Networks
How to test a cable connected to a port from Aruba MAS?
If the cable connected to the switch port is bad and in order to test the cable connectivity between the end devices.
We can run the diagnostics on the ports of Aruba Mobility Access Switches to check the connectivity of the cable with end devices.
(Switch2500) #run diagnostics interface gigabitethernet 0/0/1 cable
TDR started on interface gigabitethernet0/0/1
(Switch2500) #show  diagnostics interface gigabitethernet 0/0/1 cable
Interface name        : gigabitethernet0/0/1
Test status           : Completed
Normal cable length    : 55 metres
Pair 1-2
Pair status        : Normal
Polarity swap        : Positive
Pair skew        : 16
Pair 3-6
Pair skew        : 16
Pair 4-5
Pair skew        : 0
Pair 7-8
Pair skew        : 16
Channel 0:
Pair swap        : Straight
Channel 1:
(Switch2500) #
Version history
Revision #:
1 of 1
Last update:
‎03-26-2017 04:02 AM
Updated by:
Is this a frequent problem?
Request an official Aruba knowledge base article to be written by our experts.
