How to upgrade Mobility access switch firmware through Activate?
Q:
A:
How to upgrade the Mobility access switch firmware through Activate?
Activate Firmware Services:
This service enables the Mobility Access Switch to automatically contact the Activate server and check for any few image version
#show activate-service-firmware
activate-service-firmware (N/A)
Parameter                  Value
Activate Firmware Service  Enabled
This feature is enabled by default
To disable the activate firmware services, issue the command
(config) #activate-service-firmware no enable
Commands to upgrade :
#activate firmware check/upgrade
If the Activate firmware service is enabled, the activate firmware check command enables the switch to automatically check Activate to see if there is a new image version .
If a new version is available, the activate firmware upgrade command prompts the Mobility Access Switch to attempt to download and upgrade to the new image
(ArubaS1500-12P) #activate firmware check
(ArubaS1500-12P) #activate firmware upgrade
Image Version for upgrade: 7.4.0.4_54198
Do you want to proceed with the upgrade [y/n]:
Version history
Revision #:
2 of 2
Last update:
‎03-24-2017 06:51 PM
Updated by:
Labels (1)
Contributors
