Is cross platform Stacking supported in MAS (S3500/S2500/S1500)?
Question: Is cross platform Stacking supported in MAS (S3500/S2500/S1500)?
What is a Stack ?
  An ArubaStack is a set of interconnected Mobility Access Switches using stacking ports to form an ArubaStack. A stacking port is a physical port configured to run the stacking protocol. In factory default settings for Mobility Access
Switches, uplink ports 2 and 3 (24/48 port models) and port 1 (12 port model) are pre-provisioned to be ArubaStack link ports. Once a port is provisioned for stacking, it is no longer available to be managed as a network port. A
stacking port can only be connected to other Mobility Access Switches running the Aruba Stacking Protocol (ASP).
What is cross platform stack ?
  Stack formation of different modal mobility access switches to be a single logical switch.
S2500s and S3500s can form an ArubaStack with other S2500s and S3500s.
S1500s can form an ArubaStack with other S1500s, Cross stack with 2500s/ 3500s are not possible.
Version history
Revision #:
1 of 1
Last update:
‎11-10-2014 05:52 AM
Labels (1)
Contributors
